Eaton DC1 and DE1 Ethernet
RBergmann
Jun 2002
California
258
Hey Guys ...
I'm on site with a project that uses (9) Eaton VFDs. (2) DG1, (4) DE1 and (3) DC1 drives. Using a CompactLogix to communicate via Ethernet/IP.
I'm trying to configure the IP addresses. The DG1 is set through the parameters in the drive. The DC1 and DE1 drives require a DX-NET-ETHERNET-2-2 adapter and IPs are configured with an embedded webserver. This is all fine. I was able to configure all the drives on a one by one basis but when they were plugged into the Ethernet switch, seems that the address worked only some times. I don't know (but suspect) if the DX adapter has had past problems.
Anyone had experience with multiple DC1/DE1 drives on a closed network? Total of (14) total devices including (4) AB and (1) RTA Modbus gateway.
Hello, I’m new to this forum and if I’m posting incorrectly let me know. I’ve been having an issue I can’t seem to figure out. I’m sure it’s...
141
Hi everyone: we have Baumuller AC drive BM4463 300A 160KW, it drives Baumuller AC motor DST2-315BO54W-020-5-A (90KW;RPM 200; 365V; 215A;83Hz)...
379
Hello everybody, Since my experience is mainly with AB ladder I am having little bit of a problem with EasySoft.. Does anyone knows is there a...
852
Good morning, i have a problem with panelmate 5000 pp. unfortunately I pressed the 3rd and 5th keys while booting the Panel. Now , the alternate...
540
Hey everyone! So I'm trying to get different data from my Eaton DG1 VFD to my studio project. So far my research has led me to something called...
1,602
