Changing Homing -> Position programmatically, Kinetix 5500.
Elcan
Apr 2008
NC
935
Hi All,
Is there a way to change, in the PLC code, the Homing Position parameter that is displayed in the Properties window of the Kinetix servo drive?
I'd need to define the home position dynamically while the program is running.
Thank you!
Hi Elcan.
Yes- I believe this can be done via the GSV/SSV Functions, a good place to look is the rockwell sample code library.
If you are truly stuck- I can send you some sample code tomorrow. I do have examples for SERCOS and EtherNet/IP somwhere although im 99% sure these tags are identical in each instance.
Regards
Daniel.
It's part of the Axis object, either the HomePosition or HomeOffset. You can read it with a GSV or write it with an SSV.
288
Hi all, I am having an issue where some of my HMI push Buttons and Indicators go in to error when I navigate to a new screen. I am using a...
16
549
We have a new machine that uses an armor block to transfer input signals for conveyor position that continuously alarms out on no position change...
110
Hello everyone, I am trying to change the IP address of the Omron PLC (NJ30-1200) and HMI (NB7W-TW01B) to fetch the network on our network...
315
Dear Experts, I'm just started working with GEO SCADA and I need your valuable help. Currently, I'm trying to edit the alarm limits on MIMIC...
230
