Using FT View SE (Distributed) with 1756 PLC redundency
Hal9000
Jun 2010
London
140
Hello,
I have configured a basic 1756 system in a redundancy arrangement, as follows:
Chassis A
Slot 0 1756-L75
Slot 1 1756-EN2TR/B (192.168.1.12)
Slot 3 1756-RM
Chassis B
Slot 0 1756-L75
Slot 1 1756-EN2TR/B (192.168.1.13)
Slot 3 1756-RM
Both chassis are identical in terms of firmware and they sync ok. The 2x 1756-EN2TR modules are connected to a single ETAP which then connects to my local switch.
Eventually I will have a controlNet module located in Slot 2, I'm just doing things step by step here.
I have a FT View SE (distributed) system connected to the same subnet (local switch), however, when I perform a redundancy switch-over, my FT View SE loses connection to the PLC system. I need it to connect to the new "Primary" automatically and quickly.
According to the 1756 redundancy user manual I need do some "IP swapping", but I don't know where or how to do this?
Has anyone got experience of maintaining the FT View connection?
Many thanks in advance.
The ordinary way to do this is to let the Redundancy Modules manage the 1756-EN2TR module IP addresses.
You initially set them to be identical (yes, this violates every rule of IP addressing) and the RM sets the Secondary to be "+1" from the Primary.
When the controllers switch roles, the IP addresses are switched as well.
Where this becomes trickier is in the Ethernet switches and in the Windows TCP/IP stack, since the ARP tables need to be refreshed with new MAC/IP assignments. This is something I don't have a lot of direct experience with.
Hey all, i have a panelview screen (image attached), with 4 items on it. Program 1, Program 2, ...3, ...4. The PLC i am using is a compactlogix...
272
Hi I'd like to know the purpose of having puTTy on the PanelviewPlus 600. Can I use it to VNC to my panelview when I'm not on the same network...
1,097
I am using factory talk view studio site edition Version 8.20.00 . In that I added one media player to play video. But I cannot play it...
1,072
I have a customer who has 20 of our systems using PanelView Plus 7 Performance Series A terminals. With how hard it is to find printer nowadays...
1,684
Say I take some MODBUS registers and pull into my Logix plc DINT array (sequential). Now, I get a little fancy… using FactoryTalk View SE 13.00...
18
3,253
