B&R 2005 System
mjp123gp
Mar 2012
Savannah, GA
94
I've got a B&R rack with what's labeled B&R 2005 on the top of the rack and we're having issues with one of the I/O modules. I'm not real familiar with this PLC but was wondering if theres any software I can use for diagnostics and troubleshooting. I don't have any source code for this PLC. I know with the newer X20 system I could use the SDM webserver but the only connection I have on this one is a Profibus connection.
Without the source code, not sure if you will have any luck.
Best I can tell, Automation Studio is what you would need.
Might contact B&R tech support. They are headquartered in GA.
Confusingly, B&R had 2003, 2005, and 2010 products and those number do not have anything to do with the year they were introduced (they are all considerably older). I don't think Profibus would let you communicate to the PLC, there should be a serial or Ethernet port for that, but I could be wrong (I never used any of the 3, they were old news when I started nearly 15 years ago).
If you have Automation Studio, but no source code, you should still be able to see hardware status and even variable status for compiled routines on the PLC, just not the code itself. You'd be looking at AS2.7 as the newest version that would work and maybe older. If it was programmed PG2000, then I wouldn't even bother trying to connect. You'd have to get your hands on PG2000 and run it in a dos box and try to get it to see your serial port to communicate... easier to get a computer from a museum up and running than to get a modern computer to work with it.
Hello
I want to connect with B&R 2003.
What cable and what software is needed?
I have no knowledge of B&R Is there a USER MANUAL to guide you step by step?
Hey Guys, I have a B&R 2005 (IF260) PLC with no operating system. My PLC Parts: 3IF260.60-1 (CPU Module) 3IF672.9 (Interface Module) In order...
1,546
i have a b&r 2005 system ip161 cpu, from which i want to upload program so i want some assistance which software( i have AS 3.0) n cable is use...
4,471
Dear Sirs, I faced problem of the a.m PLC B&R system 2005 The PLC is applied on the m/c connected to the Windows NT application program. When the...
9,540
Hi, My clients have this 16 year old, but quite good machine with B&R IPC5000, PLC 2005, ACOPOS1022 servos and some Lenze 8200 VFDs. Due to...
1,474
I have a B&R 2005 plc and it looks like it uses automation studio version 4 i am try just get the program off of it so can change it to an allen...
1,068
