B&r 2005 system
rohit_plc
Jun 2013
delhi
81
i have a b&r 2005 system ip161 cpu, from which i want to upload program so i want some assistance which software( i have AS 3.0) n cable is use for this thanks.
On the B&R systems I have worked on (2005 CP260) I'm pretty sure there is no upload.... I even searched Garry's 2nd link for the term "upload" and it isn't found...
B&R, like most advanced controllers, uses compiled code on the PLC and you must do an extra step to transfer the source code to the PLC. In AS3.X and 4.X, B&R made it very easy to transfer the source code to the PLC, but in earlier versions it was a more manual process.
System 2005, despite the name, was released in the year 2000 and so is now getting pretty old. your system was probably originally programmed in AS2.X and so it is unlikely that the PLC has the source code downloaded to it. You will need to track down the people that originally made the machine to get the program from them. You might get lucky though, you can connect to the PLC using an FTP client and check the F:\ partition to see if the source code was placed there.
I don't know about the 2005 product lines, but you usually program a B&R controller with a regular ethernet cable. If not, you will probably need a standard serial cable with a null modem and a gender changer (so the cable has a female plug on both ends and swaps the Tx and Rx lines). You can make your own if you have two female, 9 pin D-sub connectors, there is nothing special about it.
Hey Guys, I have a B&R 2005 (IF260) PLC with no operating system. My PLC Parts: 3IF260.60-1 (CPU Module) 3IF672.9 (Interface Module) In order...
1,537
I've got a B&R rack with what's labeled B&R 2005 on the top of the rack and we're having issues with one of the I/O modules. I'm not real familiar...
2,464
Dear Sirs, I faced problem of the a.m PLC B&R system 2005 The PLC is applied on the m/c connected to the Windows NT application program. When the...
9,521
Hi, My clients have this 16 year old, but quite good machine with B&R IPC5000, PLC 2005, ACOPOS1022 servos and some Lenze 8200 VFDs. Due to...
1,464
I have a B&R 2005 plc and it looks like it uses automation studio version 4 i am try just get the program off of it so can change it to an allen...
1,062
