Will an 24V AC contactor work with a 24 V DC signal
katratzi said:
It may function for a short time, but as Peter said it will get very warm very quickly.
Theory there is, with AC the stated peak voltage only occurs twice for a fraction of the cycle. With DC, the peak voltage is applied all the time causing the coil to overheat, then eventually burn out.
In practice it welds all 14 of the things shut which then draws a pretty heavy amp load on the system. But no worries, no one was hurt.
Thanks again for the quality answer guys.
In an AC device with a coil and iron core there is inductive reactance that creates the necessary "impedance" (reactive resistance) in addition to the resistance of the wire to continuously limit the current. A DC device has inductive reactance only with the initial turn-on that limits the in-rush current and after that is dependant only on the resistance of the wire in the coil to limit the current.
For DC (at t> 0)
I=V/R
For AC (at t>0)
I=V/(Z+R)
Z is inductive reactance at given frequency.
So providing a voltage of same magnitude but of the type DC(frequency=0) will result in burn out of coil.
Should have hung around your computer for a few more minutes before heading back to the shop floor. :whistle:
Why would you ever try applying a power that is specifically not listed on the operating spec?
I need a little sanity check and hopefully advice from some experienced users. I have a mechanism that we're driving with a JVL MAC3000...
1,138
I am replacing a 1756-OB16E 16 point 10-31 V DC card with the above card in a 16 slot Rack with a 1756-L71 control Logix 5570 controller. The...
551
Hi, I've bought this PLC + HMI from Aliexpress, the one on the right that uses SSRs. and want to connect a 24V/0.2A DC fan to the output. My...
32
7,098
Hi Everyone, Is it Possible to downgrade to Program from version 32 to 24version..? Because I have 24 version and the program which I am going to...
1,076
Please laugh… but can I take 24volts from an IO module and wire it straight into its own input card to simulate an input….?
1,262
