How to use mmtcpbconv-vdc with Red Lion Crimson 3
secs
Aug 2015
Office
65
Hi all.
Still working with a G3 15 Red Lion panel and need to access 2 remote RS485 Modbus units. We have a new mmtcpbconv-vdc from Procon Electronics as in http://www.proconel.com.au/MMTCPBCONV.htm
Ok I can have both these units on the rs485 part, I can set the IP Address in the converter etc and I have 2 different slave id's but how do I tell Crimson 3 I want modbus at IP (since both units will have the same ip as in the converter) but the different slave id's?
Peter
I have been requested to test this proportioning valve for PLC control of flow/pressure. Dwyer Series SVP Proportioning Solenoid Valve The flow...
420
We normally ground the -24VDC side of a control systems power supply. What are you folks thoughts about grounding the -24VDC side of a class 2...
110
I have a conundrum with this current circuit. I have a Siemens 1215C AC/DC/Relay and an old drive - Ratiotrol (now Boston Gear company I...
1,172
I have begun using 480VAC power supplies in my panels to keep heat from a transformer out of the panel. This works great if the panel is mounted...
17
4,143
Good Afternoon , It seems like we always have problems with using Type J Thermocouples with our slip rings . Would using a RTD at 10...
1,644
