Changing Peripheral Port mode on Omron CJ1M
rguimond
Jul 2009
Escuminac
666
I want to use a Digi One-IAP to provide Ethernet connectivity to an Omron CJ1M. The RS232 port is connected to an HMI, but the Peripheral Port is free.
I can go on-line with it through the Peripheral Port.
In order to use the Digi One-IAP, I have to change the Peripheral Port mode to HostLink. It's currently ToolBus. Can I do this by switching the PLC to programming mode, or do i have to download a modified program to the PLC? If I change the mode while on-line, will I be able to go back on-line if something happens? I'm not 100% comfortable with Omron. I'm afraid that changing the mode to HostLink may prevent the "Auto On-line" feature in CX-Programmer from detecting the PLC.
If you have an Offline copy of the PLC Program, you don't need Auto Online, you can go Online with the normal Method. If you need to set a Serial Port back to Default, there are DIP Switches you can set. You can find them in this Manual in Section 6.
http://www.omron247.com/doc/pdfcata...FILE/CJ_series_ProgContr_manual_en_201003.pdf
I don't use the CJ1M, but I created a project, and it Defaulted to Host Link on the Peripheral Port. I believe Toolbus and Host Link are compatible, but I am not 100% sure, as I use Ethernet and Controller Link for everything these days.
Stu....
Hi to all. We need to change a bad powerFlex 525 to a new one. How do you save the configuration to install in the new one? Thank you all for...
289
Hi all, I am having an issue where some of my HMI push Buttons and Indicators go in to error when I navigate to a new screen. I am using a...
550
We have a new machine that uses an armor block to transfer input signals for conveyor position that continuously alarms out on no position change...
112
Hello everyone, I am trying to change the IP address of the Omron PLC (NJ30-1200) and HMI (NB7W-TW01B) to fetch the network on our network...
315
Dear Experts, I'm just started working with GEO SCADA and I need your valuable help. Currently, I'm trying to edit the alarm limits on MIMIC...
230
