motion controller startup
eastkodakguy
May 2002
Fayetteville, Arkansas
96
Hey guys,
I am working on a project here that involves some motion control(quicksilver controller) and I was wondering what some of the methods that the experts here use when debugging a motion controller program. Personally I turn the speeds way down i.e velocity, acceleration etc and keep a hand on the estop. Its working for me but there is probably a better way out there. Also, does anyone know of a motion control simulator out there that is reasonably cheap? thanks and have a good day
Check http://www.control.com/1026180771
We used servo axis simulator and it works just fine.
$300 per axis a little too much, but saves a lot of time, especially on retrofit projects.
Technically it's a Voltage to Frequency converter with some deadtime and lag added.
Customer also was really happy because he saw whole system running without drives connected.
I've been using Trio Motion controllers on my servo applications (and love them, by the way). Their 'Motion Perfect' software has a simulator which is great for testing programs without wrecking stuff... ;)
It might not be similar to your brand, but the software's free... :nodi:
beerchug
-Eric
Thanks alot
Thanks guys,
Eric I downloaded the motion perfect software with the simulator, this thing is awesome, sorry cont_conn its hard to beat free software such as this but I very appreciate your response alot
sincerely
Dallas Smith
Re: Thanks alot
If you think the software is awesome, you ought to try the hardware sometime!... :nodi:
beerchug
-Eric
What is a reference for the maximum jitter on the cpu of a controller for motion control? We have done some tests on an IPC with Codesys...
1,048
Hi folks, We have been working on our own controller after many decades of using the "big names". What would your ideal motion-controller be...
48
8,525
Hi, I am looking to solve error in mitsubishi PLC. Error code 7000 is currently active, which is for motion control. It has multiple controller...
841
Hi, I have a Master Thesis to write and my topic is Vertical Bag Packing Machine with continuous cycle. I am almost done with the mechanical...
4,819
I have a Delta DVP 20pm00m controller , it has O100 is the main program , OX and P are subroutines I can not enable the OX motion subroutine ...
1,074
