Ethernet connection on PC no longer working after using RSLinx to connect to PLC
one last thing to check.
When you plug in the cable do you get any of the activities LED to light up on your PCs ethernet port?
If not, it may be fried.
There are no LED's on the port connection. It just seems odd that my laptop, the maintenance laptop and another engineer's laptop all have the same problem and it has occured after the installation of RS Logix 5000 and RSlinx. Each have been connected to different processors. Each have been connected to LAN before the installations.
There are no LED's on the port connection.....
Did you mean that literally ? There are no LED's......
Or, did you mean that there were no LED's lit when you plugged your cable in ?
RSLinx version will not stop the PC's hardware from determining if a cable is plugged in.....
literally no LED's on port of laptop.
Installation of new version of RSLinx and port works now.
Tomorrow I will test connection to processor and again to LAN.
I once had a strange issue with my etherNet through rslinx that started with not properly grounding an analog module. Symptoms were similar, resolved by fixing the ground, though I never got to test it on anything else besides the plc.
Hi all, My ethernet port on my laptop recently broke and I was hoping to just use a usb-c dongle in the mean time to go live on my PLC until I...
454
Hello, I've been trying to learn this a while now and still have not found out how this works. I have an Omron CJ2M PLC and an ABB ACS 355 VFD...
244
I have a running backup of Citect and plc and I want to make a spare PC station so I have installed the win XP and somatic net v6.0 and import the...
122
Hello all! I have some machines that run an SLC 5/03 and occasionally a fault is generated. Recent Example: A power supply wasn't screwed in...
421
Hello all. I have a 1769-L16ET-BB1B, LogixDesigner v.34.011, that was brand new, factory sealed. I connected via USB port and downloaded my...
17
2,566
