PanelView Plus ---> SLC L551 Ethernet Communication Issues
Thank you Celichi for your quick reply. We were able to test it on site yesterday. There didn't seem to be consistent results from switching PLCs. Probably the SLCs and the HMIs are not on the same network. Below is the report from the commissioning team:
After changing the message to have the IP address of the HMI server, a few times, communications were gained instantly with the HMI. However, the last three times we switched PLC’s, communications were not gained instantly. As we were in the process of switching, it seemed that the old MAC address would remain in the routing tables, but after sending the MSG manually a few times, the new MAC address would appear. Even with the new MAC address in the routing tables though, The customer IT still could not ping the PLC’s from the network.
Below is the IP information:
The PLC’s have the following:
IP: 10.207.36.13
Subnet Mask: 255.255.255.0
Gateway:10.207.36.1
HMI01:
IP: 10.206.66.103
Gateway: 10.206.66.1
HMI02:
IP: 10.206.66.104
No Problem,
In my project, everything was on the same network/24 255.255.255.0.
I am NOT a network expert, but I would retest with everything on the same subnet 255.255.255.0, or open up your subnet.
With my project and hardware, the recovery was all the time, every time 1000% instant compared to running with out the dummy message.
Celichi,
Our team is going to put the SLC and HMI on the same network and try again tomorrow, appreciate if you could clarify the following questions:
1. does it matter if the tags in MSG do not exist in the HMI (panelview)?
2. do you have a MSG error bit turned on in the online SLC during switch-over?
3. in your MSG instruction, the multi-hop function is disabled, right?
Thank you!
Good evening. I am trying to get a SLC 5/03 connected to a Panelview Plus 7 Standard using a Moxa Mgate EIP3170 and I am not having much luck. I...
519
Hello, We have an older machine that has a standard PanelView (2711-T10C3) connected over DH485 to a SLC 5/04 PLC via a 1761-NET-AIC module in...
671
What some ways to connect an Ethernet only PanelView Plus to a SLC 5/04 without upgrading it to a SLC 5/05?
4,994
Will a Panelview Plus 7 (2711P-T7C22D9P) work with a SLC 5/05 (1747-L552) PLC? I assumed that it did. But, the documentation says that the...
2,756
Will a PVP7 talk to an SLC 5/05. I can't get them to talk. I have set up PVPs to Control and Compact logix plenty of times, but can't get these to...
2,505
