0-10volts simulator for my plc
ezal
Jun 2004
kl
goodday everyone,could you kindly advise me on how to make a simple 0-10volts simulator for my plc?pls advise
tks
thanks
morning panic mode and others.....appreciate your help in this matter....
later
0-10v input with Pot ... again
Hi, all.
This thread is 14 years old but I am trying the same thing today. I have a 9 volt battery, (9.64v on meter) going through a 10 kohm Allen Bradley pot... in series with a 10k, 3watt resister.
As I crank the pot from 0 ohm to 10k... my voltage at the input only fluctuates from 9.51v to 9.38v. The counts I am getting in the logic are right, so no problem there.
I would really like to get this program written BEFORE the 0-10v analog sensor arrives... but this simulation isn't working.
Any additional insight on this 14 year old thread?
Thanks all... and great forum by the way!🍻
Eliminate 10K resistor.
Connect + of battery on CW.
Connect - of battery on CCW, and Common of Analog Input.
Connect Wiper of pot (center terminal) to + Input of Analog card.
I use a PLC analog output to simulate the PLC analog input.
0 - 10V out connected to 0 - 10V in. Just add a 24V power supply.
I can program it any way I want ... even use a different PLC to do the simulating ...
Good idea, but a guy lashing up paper clips with electrical tape to a 9v battery is hardly going to have a spare PLC with analogue outputs to hand.
TRANSDUCERS CONNECTED TO PLC'S GENERALLY PROVIDE A 0-10V SIGNAL OR A 4-20 mA SIGNAL. INVESTIGATE AND EXPLAIN WHY THEY ARE USED THANKS
30
6,627
I’m attempt to establish a communication between two simulator M580 CPUs, using a READ_VAR, I have two vitalization Windows 10 in VMWare and each...
47
Showing a new guy basic programming and remembered the simulator here. But nothing happens when selecting the link. "Try our online PLC Simulator-...
25
1,627
My PLC (S7-1200) and HMI (KTP-1200 Basic) has been delivered on-site to the customer. To be able to do "off-line" updates to the code, I am using...
224
hi everyone please give me a solution to timeout error in delta plc simulator,i have a doubt about firewall and antivirus we r using.
780
