15.6" touch screen
walkir
Feb 2019
California
32
Can you suggest any good quality 15.6" touch screens with DVI?
I have several machines using CP2916 from Beckhoff but they start braking one after another. So far I had to replace 10 of them, lead time from Beckhoff is 36 weeks and prices are also not the best. I would need something more reliable, looks like Beckhoff hardware quality is very poor.
I am not using Beckhoff, but another department in my company is switching over to Beckhoff panels due to availability issues with Siemens IPCs.
Out of interest, what is it that is breaking on the Beckhoff Touch panels ?
Touch screen stops working, display is still fine but it is not responding for touch input.
We have horrible lead times for all Beckhoff equipment and everything is braking after 2 years. So I am heavily looking into alternatives.
They advertise a lot but not deliver promised quality.
I've used Hope industrial touch screens for that last several years if its a PC application. 23" screen is around $1k, they are usually in stock.
10 screens sounds like an environmental issue. I would ASSuME that they are hitting the screen and killing the touch cells.
I had 1 customer that would give them a USB mouse and keyboard when they broke a screen. Every now and then I would put in a 7" screen inplace of a 15" screen. He did that as a reason for the employees to treat the equipment better .
Have you asked a Beckhoff rep to come in and evaluate your situation? Are these on machines you built yourself or did they come from different vendors? What sort of environment are they deployed in?
If the underlying problem is with the application or the environment you could spend a lot of time and effort migrating to a new platform that might not perform any better.
It is in a clean room, and yes, Beckhoff have seen it... No comments from them we just RMA everything. We have touch screens in the same room from other manufacturer but they don't make it in 15.6" size.
So definitely it is problem with Beckhoff hardware quality.
We’ve been using Beckhoff CP3915 in cleanroom environments a lot and they always worked well. Of course, if you must have panel-mount form factor, this will not do
Just to close the topic, we decided to go with Siemens Screens, they have similar format and looks much better and have 10th of the lead time.
Currently we have a fat( I think that is what it is called) Intouch application. An application resolution of 3840x1080, and inside that 2x...
90
Hi guys We're in the process of creating a ME runtime to operate on a PC running windows using a InTouch INDT156 touchscreen, and we're having an...
140
I have a managed InTouch Application that I deployed changes to through Archestra IDE yesterday. The only changes I made was adding a solenoid...
98
Hey all! Long time reader, first time poster! I have an EA9-T7CL and an MicroLogix 1200 connected via DF1. I'm all good and got everything mostly...
651
Has anyone ever replaced a touch screen on a legacy Red Lion G3 series HMI?
1,456
