1747-UIC frustration
lanman said:
When our shop purchased a 1747-UIC, I couldn't get it to work on my toshiba laptop. I brought it home over the weekend to try it out there. Same problem. The led's showed that all was well, yet nothing showed up in rswho. After several hours of messing about with it, I changed the comm port from 4 to 5, then 6, then 7 etc etc, then when I got to comm 10 it worked!
On the monday I tried it on the laptop again. It still didn't work..I then tried comm 10, and all was well! Out of curiosity I tried comm 4-9, and it didnt work with those settings. Being even more curious, I also tested it on 3 other machines at the shop. In every case, it didn't work until I changed the comm port to 10 or above.
Check out that fix I posted up above describing the change to the Latency Timer in the Device Manager.
Hi all I am working with a SLC 5/02 and having trouble getting online with it. I am using a 1747-UIC adaptor which allows for USB>serial and...
149
se me desprendieron los cables del cable usb quiero soldarlos pero no se como van los cables si alquien me pudiera proporcionar una foto o como...
423
Hi again, so this new client has a SLC 5/02 with a DH485 port. I have the older white 1747-UIC adaptor, which I have only ever used for the RS232...
1,317
Hi Everybody! Has anybody ever tried using the 1747-UIC (USB to DH-485) converter as a straight USB to RS-485 converter? Since it present to the...
2,460
Hello I will make it short and sweet. I need the cable that goes from the slc 501 to the 1747-UIC RJ-45 connection. From what I can find it...
1,275
