1747-uic to panelview 1400
dajohn6
Sep 2006
Georgia
21
I'm trying to connect a 1747-uic convertor to a 1400 panelview. The pv is on DH+, so the serial port is for printer only. I'll need to go through the DH+ port. I have done this before using what looked to be a homemade cable, but the networking man no longer works here and he had the cable. The cable was blue hose, but the real problem is the rj45 connector that connects to the uic module. I don't know the pin-out nor can I find anything on the web or through our local AB supplier. I am trying to make some changes to the pv but I am unable to communicate with it. Has anyone had experience with this or is there another way to communicate with the pv?
Number one thing with Panelview questions is to give us the complete catalog number of your PV.
The 1747-UIC is a USB to DH485 converter. It will not communicate with a DH+ device.
If your PV is a standard PV and there is not a printer connected to the printer/AUX port. That port default setting is DF1 protocol. Check the configuration screen for its setting. Configure RSLinx for DF1 driver and using a straight thru cable you should be able to upload/download to your PV through its serial port.
Hi ! everyone. Nice to have a outlet to share experiences. Has anyone used a 1747-UIC to upload direct to a panelview using DH485 protocol. We...
2,470
se me desprendieron los cables del cable usb quiero soldarlos pero no se como van los cables si alquien me pudiera proporcionar una foto o como...
413
Hi again, so this new client has a SLC 5/02 with a DH485 port. I have the older white 1747-UIC adaptor, which I have only ever used for the RS232...
1,304
Hi Everybody! Has anybody ever tried using the 1747-UIC (USB to DH-485) converter as a straight USB to RS-485 converter? Since it present to the...
2,450
Hello I will make it short and sweet. I need the cable that goes from the slc 501 to the 1747-UIC RJ-45 connection. From what I can find it...
1,263
