1769-IR6/A RTD reading
AnotherPLCguy
Nov 2014
Chicago
Hello all,
I am fairly new to the PLC world and doing some self learning to pick up the nuances. Your help is highly appreciated.
Question: I have a 1769-IR6/A RTD module in the field and have my configuration sensor type set to 100 ohm pt 385 type. When I connect a 20 ohm direct resistance across SENSE and RTD (EXC and SENSE are shorted), I get a value of -1950 on my ChData.
Is this value my temperature ? If so, what is the formula behind it ? I know this sensor type would read 0C at 100 ohms.
Many Thanks !
Hello Bering, thanks for the prompt response ! I had already looked at that document and the pages you suggested. Below are the details of my configuration file:
Data Format - Engineering Unit X1
Sensor Type - 100 ohm Pt 385
Units - C
Open Circuit Response - Upscale
Excitation Current - 1.0 mA
Filter - 60 Hz
Could you now tell me what that value -1950 means ? I am still unable to figure out the math.
Thanks !
Hello, im using a mircologix 1500 plc with a 1769-IR6 rtd input card. I am having trouble getting the readings from the rtds to displays as values...
18
5,847
Good Morning , I have a Compactlogix application and I'm adding cards to it. I purchased new cards and I'm selecting the FW versions of the...
990
Does anyone know what the data transfer rate for this series of CompactLogix PLC's? 1769-L24ER-QB1B to be exact. Cheers.
98
I have a CompactLogix 1769-L31 and need to communicate with it. I only have studio 5000 on my computer. However, when I try to start a new project...
398
I have a 1769-L24ER-BB1B and I am trying to flash it to 34xx, its flashing red and faulted, when I try to flash it I get a popup stating it needs...
256
