1769-L33ERMS CIP Issue
chawkey
Jan 2023
Michigan
Hello,
I am commissioning a 1769-L33ERMS compact guard logix 5370 safety controller and am running into an issue with the safety ethernet devices.
I have 4 kinetix servos 2198-HXX-ERS2, an armorblock 1732ES and area scanner. I'm not very well-versed in cip safey and SNN and what-not. But what I am experiencing is that when the plc is in program mode, I can communicate with and read values from the safety devices, but as soon as I switch to run mode in the plc, the safety devices fault and timeout. A repeated faulted > connecting > running > faulted pattern.
The PLC does have time-synchronization enabled and is the master.
I'm at a loss for what to look for next, any thoughts?
Edit: Code 16#0203 - Connection timed out, error on the modules
Thank you!
Update: The safety task was executing at a rate too fast for the system to accommodate, lowering the safety task interval fixed the issue.
Hi, I have an 1769-L33ERMS that I swapped out for a spare because it was causing issues. When power cycled it would hold the Ok and Safety Ok...
605
Hi All, I have a safety compact logix PLC. I was wondering if anyone has experience in getting both of the ethernet ports on the device to have 2...
3,329
Does anyone know what the data transfer rate for this series of CompactLogix PLC's? 1769-L24ER-QB1B to be exact. Cheers.
98
I have a CompactLogix 1769-L31 and need to communicate with it. I only have studio 5000 on my computer. However, when I try to start a new project...
398
I have a 1769-L24ER-BB1B and I am trying to flash it to 34xx, its flashing red and faulted, when I try to flash it I get a popup stating it needs...
256
