1769 OF2 and external voltage
John Morris
Sep 2015
San Antonio
689
Morning all,
I am modulating two different item in this set up.
One will accept an external source 0-5. (Chnl1)
The other is an Eaton DE1 VFD which, I am reading, requires it's own source (0-10v) for modulated control.
Is there a way to get the 10 volt signal thru the analog module?
I have read the analog modules 1769-um002, the I/O modules specifications 1769-td006, and Publication 1769-IN049A-EN-P for reference
and found only this "Voltage outputs (Vout 0+ and Vout 1+) of the 1769-OF2 module are referenced to ANLG COM. Load resistance for a voltage output channel must be equal to or greater than 1K Ω ."
I "assume" this is the input for the Eaton 10v. Could anyone confirm please
PLC L33, module is 16th and fourth from the PA4
Thank you for your time and attention.
You assumption is correct. The resistance for the complete loop (including wire) needs to be above 1K. I am assuming this is because if it is less than 1K the current draw will be larger than the module can handle.
I would look up the impedance of the Eaton Drive. If you cant find it easily just put a DMM on the wires to the Eaton and see what you get for resistance. More than 1K you are good, less than 1K add a resistor to the loop to get it above 1K.
Hope this helps.
I have Studio 5000 v30 and trying to set up an analog input. I noticed through another thread there are extra steps. I looked up the manual and I...
519
I am getting max counts on my analog input 32640 on a temperatur transmitter. I have a compactlogix L24ER and I added a 1769-IF4XOF2 in slot 2...
37
3,002
I working with a A-B 1769-OF2 (2 channal analog Output module). I have replaced the OP213 optocoupler on the board and gotten the P/S +/- 15 VDCs...
2,267
Hi all wiring in the above card and the PDF from AB is fairly vague in showing how to wire in a current output. I am connecting a sampson valve...
2,565
This is my first time using a 1500. Now that it's installed I see that the minimum change (input) is 128 bits. I suppose this is what's meant by...
2,097
