24VDC and 110VAC in same conduit
NetNathan
Nov 2011
Corona, CA
2,199
I have some 24VDC contact signals and 115VAC to the coil of a contactor to go to an enclosure.
Is there anything wrong with running the 115VAC with the 24VDC in same conduit? I don't really want to run 1 conduit for the 24VDC wiring (5 wires) and another conduit juts to carry a 115VAC signal and neutral.
Use a surge suppressor connected to the contactor coil and probably it will run fine on one conduit.
Some contactor brands like Schneider have suppressors on the catalog
Depending on how high the current is at the 120V circuits, and how sensitive the devices on the 24VDC circuit are, you can occasionally get inductive coupling on the 24VDC wires that will do something like not allow a DC circuit to drop out. It's easy to fix, it's just something to be aware of.
I have been requested to test this proportioning valve for PLC control of flow/pressure. Dwyer Series SVP Proportioning Solenoid Valve The flow...
423
We normally ground the -24VDC side of a control systems power supply. What are you folks thoughts about grounding the -24VDC side of a class 2...
117
I have begun using 480VAC power supplies in my panels to keep heat from a transformer out of the panel. This works great if the panel is mounted...
17
4,147
Good morning, could anyone recommend a 24VDC pulse counter which counts up or down to a preset #? Once it reaches this number, send a 24VDC back...
1,650
UL 508: Any reason I can't supply a 60W 24VDC power supply from 2 legs of 480VAC? Our MechE is asking, it is for a product I don't deal with. My...
5,881
