24vdc coil surge suppressor
I think both Varistor and RC network are for use with AC coils. DC coils are more usually used with diodes. I was going to Google to confirm but we have had major electrical supply problems and the internet hasn't fully recovered yet.
I was using Moeller contactors and they don't offer suppression for their DC contators because they have it built in. Maybe that is why Fugi don't offer anything for their DC coils. Varistors aren't 1 time devices unless they are too small for the job. They should discharge the energy and then recover back to normal as their temperature drops.
DC surge suppressors are simply diodes wired reverse across the coil.
When the DC voltage is dropped to a coil it may generate a pulse of reverse DC that the diode would short out and protect the control circuit / PLC output.
EDIT: Some DC relays have this built in, that is why if you wire it backwards you get a direct short, while other brand relays still work wired reverse - and some don't show a polarity preference.
Good discussion. Some may not be aware that many PLC transistor output cards also have a diode on each output. Not sure if that's intended for surge supression but I would have to think it works for that. Would be curious if anyone knows how effective it is (diodes too small?) or if supplemental surge suppression is still recommended.
(diodes too small?)
The commonly used 1N4001 is small itself. The reverse pulse that would go through it is so small of a current that the 1N4001 is overrated for the job.
Just to CYA I would still put a diode on the relay itself, maybe the PLC or output card will be changed in the future that doesn't have them, or the output diode does die because 24V got hooked up to the wrong terminal, or ...........
I have a need for an alternating or ratcheting relay with 24vdc coil. Each time the coil fires, the relay needs to switch states. I found one...
3,702
I have 2 - 24vdc coils and 3 0-10vdc pressure transducers. When I turn on one of the coils I get a 150psi gain on all the pressure readouts. When...
2,665
I have been requested to test this proportioning valve for PLC control of flow/pressure. Dwyer Series SVP Proportioning Solenoid Valve The flow...
422
We normally ground the -24VDC side of a control systems power supply. What are you folks thoughts about grounding the -24VDC side of a class 2...
117
I have begun using 480VAC power supplies in my panels to keep heat from a transformer out of the panel. This works great if the panel is mounted...
17
4,147
