319CPU and 2 ET200M stations, but standaard ethernetcables ?
userxyz
May 2002
any
2,768
Hello,
My collegues placed standaard patchcables in the cabinet, this for the profinet network...?
1. I'm having troubles to get the ET200M online.
2. Is this okay for Profinet IO ? No shielded connectors... ?
Kind regards,
Combo
My experience is that the cheap plastic rj45 male ends
do not fit tight into the female IM rj45 sockets
I use the Siemens shielded cable and metal connectors
Et200m
There is an MMC flash card in the ET200M's.
That's what's bothering me... It's the first time I use ET200M on profinet. With profibus, you give the modul a profibus adres by dips. But now with profinet...
How to download the PN name + IP ? From the Hardware config ? I can download to the CPU, but nothing else is asked to me... ? No search for further devices or anything.
Kind regards,
Gerry
I mean, did you download the names+IPs to the ET200M stations ?
There must be an MMC flash card in the ET200M for only storing the PN name and the IP.
from Simatic Manager
PLC> edit ethernet node
browse and assign from there
Make sure the name you assign matches the hw config name and ip
hkrack2 for example
i want to connect reomte profibus slave i/o to s7-300 station.
which modules should i use for this application? plz help
I'm just trying to figure out the right method of adding a DO card to an existing rack. It's not the *next* open slot, but I have to move the AO...
565
Hi, A customer is requiring a ET200M in our control panel, I have never used them and would appreciate some help regarding if I understand it...
818
Hello friends I am about to get crazy, I am trying to connect a ET200M (Siemens) to a Prosoft card, the part number is MVI56-PDPMV1 in a...
5,122
Dear Experts, I have a question regarding the redundant S7-1500 CPU and ET200M connection. Will ET200M IOs work on a redundant S7-1500...
2,118
Hello, With regards to the bases of the ET200M and ET200 SP HA is there an appreciable difference in the physical footprint of the bases? From...
2,441
