4-20mA 12v DC drive
cateid
Mar 2016
Bergen
Hi everyone.
im doing a school project making a PLC system regulating temperature in an big fiber switch node.
for simulation im going to run 2 small 12v dc 0,46A fans. 1 fan for simulating the 48V "freecooler" and 1 for simulating an AC compressor for whenever the "freecooler" struggles.
My question. i need an drive that can regulate output from 0-12-15v depending on an input signal of 4-20mA. max current is 0,46A so i want it to be ok for about 1A.
i know this is ok to "DIY" but i don't have the time nor the rescources available.
i need to buy a finish component that i just can plug too a PS and connect fan and my 4-20mA signal from my PLC. also shipping must be within 1 week. ebay is to scary from norway as chineese components are rated with about 1 month shipping time.
Big thanks in advance.
Cato
Normally you would regulate a small DC motor with PWM (pulse width modulation).
Some PLCs actually have a PWM output so no need to use 4-20mA in that case.
Yea i know.
But now i need a linear 0-15 or 12V drive that adjusts based on a 4-20mA input.
At that price point? A cheap Arduino to take the analog signal(convert to 0-5v with a resistor) and output PWM to a mosfet to switch the 12v.
Edit: Because I don't know of any kind of drive that's that inexpensive otherwise
PWM i got on my PLC.
Not what i am asking for.
But thanks anyway
yep arduino would do it for this price and situation very good, i made them to open a valve with pwm at 2Amperes indeed with a simple mosfet (BUZ11)
another way is by using a simple transistor and 2 resistors for current control.
20 mA for 12 Volt means 600 ohm on the base of a NPN to ground, the output will try to keep this 12 Volt, (oke -0.7Volt) so the emitter can direct go the motor.
as it is only for simualtion.
At that pricepoint, the I think the best you might be able to do is get a small relay and switch it on and off. I'd love to be surprised, but I doubt you'll get a Commercial Off The Shelf (finished component) variable speed drive for anything close to that price.
Hi all, I'm connecting several 4-20mA sensors together in parallel (only one shown below) The enclosure is ABS plastic with metal backplate DAQ...
295
Problem: Our PLC can only output 4-20mA, but the actuators it needs to control, modulate based on a 0-135Ohm signal. Buying 4 or 8 individual...
286
What's your go to 4-20ma isolator. I've got some 4 wire 4-20ma from several flow meters and scales that I would like to isolate before it gets to...
1,708
Hi, I need to read three 4-20mA signals from a DCS(ABB) in a remote 6 channel analog input module with RS485 modbus port. When I connected...
502
Hello this is my first post. Looking forward to being more involved in this community to learn and hopefully help others. Any help or guidance...
802
