400w speed control
shanmu_gam
Mar 2007
22
hii
I have one 400w single phase induction motor whose speed has to be controlled.can any one help me in controlling the speed cheaply with put using inverters or VFDs.
Cheaply?
That depends. Can you sacrifice a huge percentage of your motor torque? If not then the answer to your question is probably no.
Please tell what kind of single phase motor you have. There are quite a number of different designs, some more suited to speed changes than others.
Does anyone know what the data transfer rate for this series of CompactLogix PLC's? 1769-L24ER-QB1B to be exact. Cheers.
125
Hello, I am trying to setup on plc so If I enter 60 jph (job per hour) it will send the vfd hertz based on what jph is entered by...
174
Sigh, DeviceNet noob... I have a 1756-L55, with a DeviceNet module, and 10 PF700 all commanded with DeviceNet. One of the PF700's blew up...
150
Do i have to use interrupt subroutine, or immediate read high speed input, for Unitronics Samba plc or reading only the correponding register in...
136
Hi all, I'm having trouble solving a problem I've been working on for several months, and thought you might like a stab at it. The machine runs...
22
997
