the_msp
Thanks, it's working now. My 2nd form was named "Form1" but I added a new form, "Form2" and changed the code to reference to this and it opens it.
Private Sub BasicIndicator1_Click(sender As Object, e As EventArgs)
BasicIndicator1.SendToBack()
End Sub
Private Sub BarLevel1_Click(sender As Object, e As EventArgs) Handles BarLevel1.Click
BarLevel1.BringToFront()
BasicIndicator1.Visible = True
BarLevel1.Visible = False
Method overloading is where there are multiple definitions of a subroutine using the same name. Visual Studio determines which one to use based on the parameters you pass. For example:Hi AustralIan
Could you pls elaborate, I am not a power user.
How could my call use overloaded function instead of normal writedata ()?
There is another overload just below that one: "
PublicFunction WriteData(ByVal startAddress AsString, ByVal dataToWrite() AsString, ByVal numberOfElements AsUInt16) AsInteger"
The DigitalPanelMeter only comes in red digits. It's in the embedded graphics and cannot be changed. However there is a 7 segment meter that is part of the Meter Expansion pack that changes between red and green based on limits of the value.Gents,
I think I miss something..
I want to change the color of the digits from the panelmeter...Can anyone point me in a direction to do this?
It must be somewhere in the code of the panelmeter...I think....
Asynchronous reading is better, and subscriptions are better yet. There is a trick to using subscriptions and avoiding all of the complexities of the code writing.DF1Comm1.AsyncMode=False
Label1.Text=DF1Comm1.ReadAny("N7:0")
Is there some other way other than a timer where this code should be???
In the BasicLabel there is a property NumericFormat. Set this to 0.00 and it will round to 2 digitsOne other question I have is if you are reading a F8:0 and all you want to see is 19.70 but the value is coming from the plc as 19.7068475 can you limit the amount of characters some how??
There are two properties named HighlightColor and HighLightKeyCharacter that will do part of what you have done. If your message contains the KeyCharacter, then the background will change to the HighLightColor.And for the short cut or fix I have is to be able to change the
MessageDisplayByValue to have different back and fore color's or text size I just don't know how to paste it in to this reply as coded text
anyone that can let me in on how to do that it would be great!!!
[FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff]Private[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff]Sub[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][FONT=Consolas][SIZE=2] MessageDisplayByValue1_TextChanged(sender [/SIZE][/FONT][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff]As[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][FONT=Consolas][SIZE=2] System.[/SIZE][/FONT][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#2b91af][FONT=Consolas][SIZE=2][COLOR=#2b91af][FONT=Consolas][SIZE=2][COLOR=#2b91af]Object[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][FONT=Consolas][SIZE=2], e [/SIZE][/FONT][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff]As[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][FONT=Consolas][SIZE=2] System.[/SIZE][/FONT][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#2b91af][FONT=Consolas][SIZE=2][COLOR=#2b91af][FONT=Consolas][SIZE=2][COLOR=#2b91af]EventArgs[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][FONT=Consolas][SIZE=2]) [/SIZE][/FONT][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff]Handles[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][FONT=Consolas][SIZE=2] MessageDisplayByValue1.TextChanged[/SIZE][/FONT]
[/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#008000][FONT=Consolas][SIZE=2][COLOR=#008000][FONT=Consolas][SIZE=2][COLOR=#008000] '* If the message contains a "?" then set the text color to Yellow[/COLOR][/SIZE][/FONT]
[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff] If[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][FONT=Consolas][SIZE=2] MessageDisplayByValue1.Text.IndexOf([/SIZE][/FONT][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#a31515][FONT=Consolas][SIZE=2][COLOR=#a31515][FONT=Consolas][SIZE=2][COLOR=#a31515]"?"[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][FONT=Consolas][SIZE=2]) >= 0 [/SIZE][/FONT][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff]Then[/COLOR][/SIZE][/FONT]
[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][FONT=Consolas][SIZE=2] MessageDisplayByValue1.ForeColor = [/SIZE][/FONT][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#2b91af][FONT=Consolas][SIZE=2][COLOR=#2b91af][FONT=Consolas][SIZE=2][COLOR=#2b91af]Color[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][FONT=Consolas][SIZE=2].Yellow[/SIZE][/FONT]
[/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff] Else[/COLOR][/SIZE][/FONT]
[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][FONT=Consolas][SIZE=2] MessageDisplayByValue1.ForeColor = [/SIZE][/FONT][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#2b91af][FONT=Consolas][SIZE=2][COLOR=#2b91af][FONT=Consolas][SIZE=2][COLOR=#2b91af]Color[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][FONT=Consolas][SIZE=2].White[/SIZE][/FONT]
[/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff] End[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff]If[/COLOR][/SIZE][/FONT]
[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff]End[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff]Sub[/COLOR][/SIZE][/FONT]
[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT]
