A/I module 1756-IF16 Allen Bradley
hareth
Aug 2021
Ankara
Hi all,
installed on chassis A17 an A/I from Allen-Bradley , problem is what ever I do , all channels are sticked on value 39.9 and cannot change it
please advise
Is there a way to see what the actual field signal value is going into each channel of the Analog Input I/O card 1756-IF16? In other words, I...
3,694
I have a 1756-IF16 Analog Input Module. It is setup for Differential Mode. I am trying to read the 4ma to 20ma signal from a flow meter. I am...
49
12,041
hi guys I am confused about how to use 1756-IF16 in Single ended mode, please see my attachend picture, in the picture, is the "user provide...
4,446
Hi, Last week I faced a problem with a 1756-IF16 analog input module. All the channels being used started showing 15-20% greater values than...
4,561
I have a 1756-IF16 module wired for single-ended inputs,that has 2 channels (6 & 14) which will go to zero randomly.I have swapped out the module...
3,236
