AB 1400 1766-l32bwa
A note if you don't have that attachment handy: A-B's usual default for onboard low-pass filtering is 8 milliseconds or 60 Hz.
This is of course to provide tolerance of the most common induced noise in North America, from 60 Hz AC power circuits.
Because the default filter isn't zero, it's common to set up an encoder application then wonder why it only works at very low speeds. I've definitely done that.
Yes, I set up a high speed counter and did not receive any count on default but could see my input going high/low. I found the quick start guide and was off and running.
Thank you
Would it be best practice to keep the filter as high as i can with proper performance to avoid noise or should i just set to 5 micro-seconds?
it is unaffected by noise right now and running fine.
Hello all, I'm just starting out programming and having an issue. Is there any way to get a floating point data file into a string data file...
940
Does it have Ethernet port and support Modbus TCP? I was told Ser. B would support but not A. But not sure where to find the documentation...
1,761
ml1400 (1766 L32BXB) problems with communicacion ascii I configured the channel 2 like ascii, 9600 baudios, parity none, stop bit 1 , data bit 1...
1,807
Hey I'm a student working on a project. I trying to control a 0-10V driver using the analog output on the ML 1400. To test and output I've been...
26
9,527
i need to configure a linear transductor Balluf 1300 mm at the analog input IV0. I need a sample program. Help me please.
2,118
