AB 1769-L35E and 1769-SDN/B issue?
jags
Oct 2013
uk
Hi All,
Newbie here! Could someone please help me.
I'm setting up a plc atm. Its basically a 1769-L35E/b with 2 1769-SDN/B cards in it.
I flashed the cpu fw up to 16.whatever.
When I setup a program in logix, I create a new module, communications adaptor,1769-sdn, the card is a v4 but the only options for major revision are 2 or 3.
I have the eds file for v4 in linx as when setting up the .dnt file, I can put in a v4 card along with the various dnet devices.
What am I missing?
Use Rev.3 and you will probably be fine; just use "Compatible Keying" as the Electronic Keying option when adding it to the Project Tree instead of "Exact Match".
It probably has to do with the age of your copy of RSL5K (Modules Profiles); Rev.4 is fairly new and at the time your copy of RSL5K was installed it didn't exist within the user software database.
If you want to "Key" the modules "Exactly", install a later RSL5K revision such as 18 or 19 or the latest Rev. 16 minor; the Modules' Profiles installing with RSL5K Rev.18 or 19 will probably become also available with your copy of Rev.16.
.eds files are used exclusively by the RSLinx and RSNetWorx utilities.
Thanks Buddy. I already set it to Comp Keying and it works. I may flash it back to v3?
Go for it, but why?...:unsure:...I'd be very careful downgrading firmware, especially when not in an emergency...:D
Hello, We have had a machine running for the last 10 years. It has 2 x Kinetix 300 drives. Around a year ago, one of the drives failed. We were...
428
Hi, I recently tried to change the IP address of my 1769-L35E Series A, since doing this the MS indicator is flashing red and the NS indicator is...
936
Good morning guys. Im triying to communicate 4 JXC91 with a 1769-L35E AB CPU. I already test the JXC91 with a newer AB CPU using eds files and...
1,460
Good Morning , I'm looking for a cheap 1769-L35E processor. I know this CPU is obsolete. I'm preparing for a obsolescence project , but the...
1,187
Hi Guys, Question - does the subject title AB processor act as a processor AND comms module? It does have communications ports available on the...
967
