AB SLC 500 Comm
yes you can, but you may not be able to connect through the DF1 port (9-pin d-shell) depending on how you have it configured. Depending on what processor you are using you can connect through the DH+ (5/04) port, dh485 port (5/03, 5/02) or ethernet if the processor is a 5/05.
Thanks for your reply. I am very much used to DCS systems but know very little about PLC's. I have found that the DH+ Port may not be set to match my Laptop. I will find out tomorrow I hope
Thank you for your help.
selftaut said:
If I have a printer connected to the 9 pin connector can I still talk to the processor with a Laptop?
To connect to the DH+ port from your laptop you will need a PCMK card and the correct cable.
Our plant is currently going through a DCS change to a Siemens T3000. We have been running F.A.T. at the Siemens location. The problems we are...
4,083
G
Hi Guy's, Need a little help. I have a SLC -500 1747-L20C, I also have a 1747-PIC Ser. A. I start RSLinx, Go to Communications, select Configure...
2,382
I have a program that I've used 100 times. SQO settings: File N7:0, Mask 0FFFFh, Dest B3:1, Control R6:0, Length 8, Pos 2. Length & Position...
48
988
Everyone, i am in the process of purchasing the Slc 500 version of software to support what we have and i have a question. Several of our...
776
In a slc 500 plc I am trying to move data with out using a lot of moves. I want to move data from n7:1 to n7:2 and data that was in n7:2 to n7:3...
1,371
