Ahhh yes, I had assumed you had tried the normal download and the fault had persisted. I have seen surge related faults before keeping the processor at a 0001h fault state, so I knew it was possible. I didn't read between the lines enough.
To Download, you need to "point" RSLogix 500 to the processor path, via the "Comms" window, but you do not "go online" to a defaulted processor when attempting to Download an initial program to it. You just select "Download" and it uses the currently selected path. To always use this path, under "Comms>System Comms..." click on the processor and then tick the "Apply to Project" box in the bottom right corner. Then "OK" and Save the project. Then perform the Download.
EDIT: Everyone is quicker than me! (I'm too particular...)
G.
G.
