AB Thermocouple Cards
Christoff84
Jun 2006
Cambridge, ON
407
I have a few thermocouple cards (1746-NT4) I managed to scavenge off a kiln we decommisioned. The only issue with these cards is that the thermistor for the CJC is missing. I can't seem to find a replacement part number, and my AB rep won't answer me on the subject. Does anyone have the spec's (temp range/resistance range) or replacement model number for these?
Not sure you can buy them separately, you might have to buy the whole terminal block Part No. 1746-RT32. See pic below for CJC part no.
Radio shack sells thermistors, And if I remember you can see the cold junction temperature when viewing the inputs on the card (decimal) if it's close to the cabnet temperature than it's good to experiment with.
You could try a resistor but then your "cabnet" temperature would never change, but if your just playing around then it's good to go
Clint
I am having an issue getting a IY4 to read my thermocouple correctly. We have a R type and K type hooked up and sitting at a known room...
536
Posted by u/mr_biodtox 44 minutes ago Delta ISPSoft - Establishing communication with thermocouple module Hi, How do I establish communication...
340
Hi, We have an ongoing project with a lot of thermocouple involved that monitor the temperature of heaters. There are more than 20 PID...
32
3,486
Hello. PLC beginner here, so apologies in advance for any incorrect terminology or poor communication. I have an SLC 500 Thermocouple/mV Analog...
651
Hello Guys, Trying to scale a thermocouple directly into my IY4 card. Connected into the terminal +\-. I’ve scaled the range of my J type to...
1,672
