Actual axis position from Gn_XIST1
CDale1989
Feb 2017
Newcastle
I am trying to acerstain whether i can calculate the actual position of a Technology axis (sensorData.sensorData[n].position) using the value is Parameter R0482 Gn_XIST1.
I am also trying to use values stored in the parameter of the expert list of an axis to calculate how many turns an encoder has completed i.e. its current multiturn value. Is this possible?
Details:
Axis type: Rotary
Encoder type: rotary, [2051] 2048, 1 Vpp, A/B, EnDat, Multiturn 4096
Program: S7T Config
Chris
The reason i want to use the parameters is for researching into how the encoder values are stored/manipulated.
I am hoping to see whether the configuration of an axis can be changed, this depends on how the multiturn information is stored.
Hi all, Just looking through the CIP_AXIS_DRIVE data type in a Logix controller to look for something that can tell me whether the current...
1,084
I've been experimenting with Motion Commands by creating a virtual axis in RsEmulate version 19.0. When I run a Motion Axis Jog on a virtual...
1,803
Why is the configuration IP different from the actual IP address still able to run normally?
839
Hello everyone, i would like to read in pcs7 v8.2 the actual day of the month(ex 1 or 25 of the month) i used as attached read_CLK AND DT_DATE but...
1,953
Hello all! I have a problem. We are using SINAMICS V20 (6SL3210-5BB17-5UV1) to move a car tire with a motor up and down. The main principle is...
1,092
