Contr_Conn
Here is what I got so far:
1 D2-260 CPU 30.4K WORDS W/16-LOOPS FLOATING PT MATH
1 D2-USER-M DL205 PRODUCT USER MANUAL
2 D2-09B-1 9 SLOT BASE WITH INTERNAL 110/220 VAC P/S
1 D2-CM DL205 EXPANSION CONTROLLER INSTALLS IN EA EXP B
2 D2-EM DL205 EXPANSION MOD INSTALL ON SIDE OF EACH BASE
1 D2-EXCBL-1 DL205 BASE EXPANSION CABLE 1-METER
2 D2-16NA 16PT 110VAC INPUT
4 F2-08TA 8PT 24-140VAC OUTPUT HIGH CURRENT 1.5A/PT
2 F2-08DA-1 8 CH ANALOG OUT 4-20MA 12BIT RES SINK/SRCE
3 F2-04THM 4 CHANNEL THERMOCOUPLE OR 16-BIT VOLT INPUT
1 D2-ANLG-M DL205 ANALOG I/O USER MANUAL
1 H2-ECOM 10BASE-T ETHERNET 205 NETWORK MODULE
1 H2-CTRIO 205 HIGH SPEED COUNTER INTERFACE MODULE
1 HX-CTRIO-M HIGH SPEED COUNTER INTERFACE MANUAL
1 D2-INST-M DL205 INSTALLATION & I/O MANUAL
1 PC-PGMSW DIRECTSOFT PROGRAMMING S/W F ALL DL PLCS 32B
1 D2-DSCBL PC PGMING CABLE DL05/06 DL105 205 350 450
Total $4,238.00
Plus new cable from HMI to PLC (home made or from E-terminals)
Also must verify if CTRIO will work with Mitsu drive.
Total $4,238.00
