Adding a New Module / Revision - Missing Somthing Obvious
Aviator|Chris
Jun 2009
Midlands, UK
39
Hi all,
I did this before but can't remember how.
I've downloaded the EDS for 1769-OB32T module Rev 3.1 from Rockwell.
I have all versions of Logix 5000 installed from 12 up to 17 if i remember the load screen correctly, quite a few versions anyway.
I used the Hardware Tool in RSLinx to install and verify the EDS file. This was successful.
I rebooted but the file hasn't appeared for use in Logix5000 modules list. Do new versions ever appear here or am I missing something between finishing the hardware tool and wanting to use it in Logix5000.
Cheers. :geek:
EDS file will not help you to have the module in the selection list of your RSLogix 5000 I/O configuration... this will just give you the possibility to *see* the module through RSLinx / RSNetworx.... :cool:
You will need to use a Generic Profile, configured as you may see in the attached screenshot.
See the Installation Instructions starting at page 16 to understand Module data files.
Hope this helps,
- [FONT=comic sans ms,sans-serif]fuzzy logic[/FONT]
Right now I'm finding an Add-On profile for these modules, this will make it more easy !
Here the LINK
The file is indicated in the attached screenshot.
Hope this helps,
Hi all. I'm having issues adding an ethernet module to my project in Studio500 v34. The device is a Fredericks Televac EthernetIP MX gateway which...
372
I have never understood how the I/O is configured using RIO. In the tree there is only the RIO module, not the racks of I/O attached or all the...
1,301
Hello I have a two controllers 1756-L61 and I would like to add an Ethernet Card module of one controller to the other one. When I search for...
884
Title says most of it. I have a module mismatch error in a Logix PLC (v30.11). The setup is for a standard I/O module, but the installed card is a...
866
No matter what version of Logix I use I am trying to add a Ballluff block and when adding the program closes with no errors. I tried adding a...
752
