Adding Point I/O to an existing Devicenet Network?
azapata
Oct 2015
toledo, ohio
I'm currently using a 1734-ADN Point I/O adapter. I would like to know how i add this to an existing Devicenet Network? I understand it is a subnet of the existing network and that when setting up the subnet network the adapter must be added at node zero than add your other input blocks after.
Device Bridging...
Hi and Welcome to the Forum!
I recently posted a sort of "step-by-step" on exactly this setup. It involves using "Device Bridging" in RSNetWorx for DeviceNet.
I actually incorrectly posted it for that thread, as the user was using a different adapter, but it may prove useful to you here?
See post #8...
http://www.plctalk.net/qanda/showthread.php?p=686499
P.s. Replace my references to "1769-ADN" with "1734-ADN" and it will make more sense!
Regards,
George
Title says most of it. I have a module mismatch error in a Logix PLC (v30.11). The setup is for a standard I/O module, but the installed card is a...
866
Hello, Fairly new to PLC programming. Have a question in regards to a 1734 Point I/O rack and the built in tag structure in Logix Designer. I...
2,142
Is there a way to add a Point IO card to a project with a control logix processor (version 30 or 31 I believe) while online and in run mode...
4,340
Hi guys, Is it possible to add new I/O point during online (Remote Run) in existing Remote Chassis via Controlnet? I want to use the existing...
2,308
I did some searching but I think this is something someone will answer quicker than I can find it. I'm working with version 15 and need to change...
4,942
