AIC+/PIC driver
supporter
Mar 2006
Malmö
167
Hi Experts,
I've a DH485-network that I want to connect RSLINX to. To be able to do so I've a AIC+-module. I will also need to use the 1747-PIC/AIC+ driver.
I've changed so that RSlinx is not running as a service anymore and now it's possible for me to select the driver. However, the driver is stopped. When I restart RSLinx it seems like the driver starts to install (I get on of those "the software you are installing for this hardware has not passed windows logo....."). I press OK and almost directly I get the following error message: Fatal error initializing PIC device driver.
I'm using RSLinx 2.50.00 and the serial port is a "real" serial port.
Do you have any suggestions?
Thanks!
//Supporter
I would try uninstalling the driver in RSlinx, then go into your computer's hardware configuration, uninstall the com port that the driver was using. After you've uninstalled it, have windows scan for hardware changes to find the com port again. This should give you a "clean" com port to start with.
Fire up linx and try reinstalling it again. You could have another program hogging the com port, hence the error when RSlinx tries to use it.
Thanks for your suggestions. Tomorrow I'll do some new tests - I'll let you know if your suggestions cured the problem or not.
Hello, I am running Windows XP SP2 and Rslinx does not have the 1747 PIC AIC+ driver available. Not showing up on driver list/selections. Is...
4,083
Let me start off by saying I know I need to get a 1747-UIC, but I can't get one in for a couple days and I'm working on something time sensitive...
9,519
I installed RSlinx Lite to a new laptop running on Win 7 and when i tried setting up the drivers, i noticed that there was no driver for...
19,811
Here is the thread that sparked this one. Basically the file serenum.sys seems to be the root of the SP3 issue with the PIC/AIC driver. It needs...
37
45,232
Is there no compatible solution for this? I feel like I am in the stone ages here. Does AB think comp manufacturers are going to start putting...
29
9,605
