Analog Input using PLC Omron CP1E+MAD11
Hi Iant,
May u guide me how to convert BCD to BIN, BIN to BCD, BCD to HEX and etc?
Starting from BCD to HEX first i think.
Thx.
Best Regards,
Budiman Chandra
If you mean by the PLC the instruction help.
please write the code and I will look at it.
IF it is basic conversion then use the Win 7 Calculator
Change it to the Program mode by the View tab.
No, i mean using Cx Programmer to do conversion.
What is the instruction?
Thx.
Hello guy I'm in problems. ...I have cp1e +mad11
I have 0-10 v input ...I want to know how to set 0-10 v input selection by analog adjuster on cp1e.. .
And input address of analog please help please
With out looking at be documentation I am fairly sure there is a dip switch to change between voltage and current
If not then it is a connection requirement.
Hello, I have a small programming task that I need help solving. I have to: * Create an analog input (4-20v)and a digital output * The analog...
45
25,167
Hi, I have a potentiometer connected to a siemens micromaster 440 to control a servo motor speed and they are not connected to any PLC. Now, I am...
4,054
Hello, I need some help adding a project to an existing PLC and HMI. We have a SLC 5/03 controlling a filtration systems. I will like to add a...
1,860
Hi all I am trying write a program that has analog input from a pressure sensor in a tank that read the pressure sensor for level when the pump...
6,591
Please help me... Is there any possible way to use AB IR4-1762 module for analog input scaling....?
1,182
