Application for SEPAM
Ginno
Guest
G
I am planning to develop a small application that can control a SEPAM through an ethernet network. But I am new in this type of programming.
In fact, my questions are:
1. Is there anyway I can get the data from Sepam directly i.e. send a request like what is the voltage or I should know where the values are stored in the Sepam registers
2. If I have to read registers, do manufactures of such equipments give all necessary info about the registers and their use.
3. If I have to read registers then one application cannot work with any equipemts that supports ModBus protocol see that they don't have same registers.
Thanks to help.
1. You need to know where the values are stored in the Sepam relay.
2. In this specific case, yes.
3. I don't know what you are asking. Different applications can access a single device, but plain Modbus networks only allow a single "requesting" device at one time (Modbus TCP and Modbus Plus are different).
Has anyone ever seen where you have a tag reading from the plc in scada. In this instance it's just a PEC, I set it up on one scada terminal and...
99
Hello everyone, Recently, my Archestra IDE shut down while I was editing. After restarting the IDE, I noticed warning symbols under my opened...
102
Currently we have a fat( I think that is what it is called) Intouch application. An application resolution of 3840x1080, and inside that 2x...
91
I have a managed InTouch Application that I deployed changes to through Archestra IDE yesterday. The only changes I made was adding a solenoid...
98
Hi All, I am taking a deep dive into my facilities HMI Thin Manager Server which has been alarming for High CPU usage. We are using FactoryTalk...
124
