Archestra String
Ones_Zeros
Feb 2014
at work
367
Hello,
I have been working with Wonderware ArchestrA objects and I ran across
were someone had used these as a string.
.Msg.#VString
I would appreciate if someone could explain what these are and how to set them up? I would assume that it displays a message, but I can't find what message it will display.
Thanks for helping
Hello,
thanks for the link. I found this in the manual regarding #vstring.
“Galaxy:Tank.PV.#VString4” is converted to“Tank.PV”
I didn't find anything in the manual pertaining to .msg
The syntax configured in ArchestA is Galaxy:ObjectTagname.
Property.Msg.#VString
I can't find were I configure what message is displayed.
I appreciate the help on configuring this?
Thanks,
So I made some changes to our plants WindowMaker application and I'm having trouble deploying the update to the live runtime. From the deployment...
132
Dear All, We are designing a solution with 1756-L74 and Archestra. We need to use SOE to show on HMI. Please mention any solution if someone did...
137
So I'm trying to enable history for a tag that is being used to display PPH on InTouch. I was able to locate the tagPath by finding the display...
699
Got myself into a bit of a jam this AM. Somehow the graphic editor hiccupped and when I went back into my graphic, everything was gone. I...
1,082
It's a while since I had used this that I forget where the setting to enable/disable object security is. There are some devices (pumps/valves)...
862
