Arrgh! Trying to setup a 1756-CFM
plc.doctor
Aug 2002
N36° 15.307' W119° 38.828
73
Trying to get a handle on using the 1756-CFM flowmeter module.
We have C.Operations[0].kFactStruct.kFactorForChan[0] set to the k-factor of the turbine flowmeter. What do we need to set for C.Operations[0].kFactStruct.FreqAtKFactor[0]?
When do we need to use the other setting for channel 0? Are they to compensate for the flow rate changing at greater flow rates?
Is there a "for dummies book" for using this module?
We used plenty of 1771-CFM's without having this much head scratching.
I can't seem to get the Panel View Plus 7 standard edition to downgrade to V_11, when I check the AB downloads and compatibility websites for this...
140
Hi I used to be able to launch PLCsim without any problem. Now it tells me " STEP 7 Professional Licence is required to simulate this PLC"...
537
Hello! When trying to load the hardware configuration I get error 0050-133 2 2458, check the diagnostic buffer. When checking the buffer, it says...
189
We have a keg check weigher that that lost a fight to a forklift. The scale was previously a Systec IT3000, which was the only PROFIBUS slave...
678
