Assigning Device Name - ET200SP
Hal9000
Jun 2010
London
140
Hi all,
I am in the throes of commissioning a single S7-1517 cpu and I'm utilising both ethernet ports, X1 and X2, with individual IP addresses. X1 is a local IO network and X2 is on the corporate network.
The PLC program has been loaded successfully into the CPU via a VPN connection routed through to ethernet port X2.
The CPU is complaining that the ET200SP interface modules are 'not reachable' and my guess is I need to assign the 'device name' to the ET200SP ProfiNet interface module. (The customer assures me they are powered up and the ethernet cables are fitted correctly).
The issue I'm having is I don't seem to be able to assign the 'device name'.
Is this because I'm connected to X2 and the IO is on X1?
Regards,
Justin
Some VPN's do not transmit the messages required to assign the Profinet names (e w o n for example).
If you configure the topology in the project and it is wired exactly as that, the device names are assigned automatically.
Hi LD
Ok, that's very useful to know, I wonder if the patch cables have been plugged into different ports on the Scalance switch.
Cheers
Justin
I can't seem to figure out how to add descriptors to I/O points on an RMC using PCCU. Say, for example, I want to use "Valve_1" as a descriptor...
75
Hello all. A little ashamed of myself that I can't remember how to do this but..... I have a 1734-AENT that I set the wheels to "888" applied...
4,083
Hey everyone I'm working on a PLC project for a series of 4 vacuum pumps. I need to be able to rotate each pump into a different priority based on...
18
6,475
With FactoryTalk ME is it possible to use a single Trend object and list of pens being displayed using macros? Would like to have one Trend object...
1,769
I had a 1794 AENT ethernet adapter card go bad. Tried to replace and cannot seem to get the replacement to work. I've tried everything I could...
1,871
