Assigning Trend Pens with Macro in FT ME
sanger
Nov 2005
Toronto
172
With FactoryTalk ME is it possible to use a single Trend object and list of pens being displayed using macros? Would like to have one Trend object plus a set of buttons that selects which set of pens are displays.
To my knowledge, you can only do this in FTVSE, but I could very well be wrong.
A way around this would be to create this feature in the PLC itself. Create 10 tags that are holding points for the values you want to trend, and then use your push buttons on the HMI screen to activate different rungs of logic that shift different tag values into those holding tags. You can use text with visibility animations to display which values are currently being displayed.
I just make another display with a seperate trend object, and the "buttons" that select between them are actually goto display buttons.
I can't seem to figure out how to add descriptors to I/O points on an RMC using PCCU. Say, for example, I want to use "Valve_1" as a descriptor...
75
Hello all. A little ashamed of myself that I can't remember how to do this but..... I have a 1734-AENT that I set the wheels to "888" applied...
4,081
Hey everyone I'm working on a PLC project for a series of 4 vacuum pumps. I need to be able to rotate each pump into a different priority based on...
18
6,475
Hi all, I am in the throes of commissioning a single S7-1517 cpu and I'm utilising both ethernet ports, X1 and X2, with individual IP addresses...
1,718
I had a 1794 AENT ethernet adapter card go bad. Tried to replace and cannot seem to get the replacement to work. I've tried everything I could...
1,868
