theColonel26
I have heard that in Europe the most common wire number scheme is a unique number for each wire. As opposed to wire numbers based on "Net" that is common in the U.S.
For Example: Positive control power (after breakers fuses etc. ) in a "By Net" scheme you may have 50 wires that supply power to different things. They all would have the same number.
In a number "By Wire" scheme you would have 50 different wires each with their own number.
(Yes "By Wire" is still done in the U.S. but it's not as common)
Thoughts?
Thoughts?
