B&R Automation Studio compare block output
Amation
Jan 2010
Murrylands
I am using LE & GE blocks in an Automation Studio ladder program when I build it tells me I cannot take a output coil of the Q output. I had the same issue with timers and recified the problem by using a NO contact in a new rung to drive te output. This solution will not apply to the compare block as they are not addressed so there is no way to identify a contact. How do I overcome this issue?
Hi, I have been trying to run drive via Sysmac studio. I can ping the drive. I can see the logic bits going on/off as per command. But, drive is...
21
570
Hello Experts, I recently stumbled with an issue about ABB VFD ACS800 connected with B&R PLC X20CP1484-1. This ABB VFD ACS800 somehow got...
325
Hi, I would like to prepare a project for the operator panel and I do it like this: New project -> I choose the appropriate panel -> add object ->...
428
Hi, I would like to prepare a project for the operator panel and I do it like this: New project -> I choose the appropriate panel, it seems to me...
640
Hi all, I am working with an IO link sensor (measuring current across motor)and need to read in and store the sensor values for 5 seconds, then...
1,215
