Have a few questions about backing up.
I have an SLC 5/05 CPU (1747-L551) with a battery warning since a couple of days back. From reading here I understand the capacitor can't be trusted even if it should hold the memory for 30 minutes according to the manual.
Have no working backup of the PLC program.
The "RS232" port below the "ENET" port is connected to an AIC+ (1761-NET-AIC) with a 9-pin DSUB in the CPU end and a mini-DIN on the AIC+. The DH-485 port next to it is connected (to the Panelview 900 - nice amber single color - I assume) and the 9-pin DSUB below it is unused. Speed setting is set to "Auto", there's no address written in the little white area on the front of it. Voltage is set to "External".
So... I made a cable according to this image:
http://thientruongpc.com.vn/image/d...RADLEY/RS232 F F/1747-CP3 RS232F-F 3M_8_1.jpg
... and I also used a null-modem cable I already had which is tested and working between to PC:s running terminal programs.
I installed Windows XP Professional and all update packages, RS Logix 8.10 and RSLinx Classic Lite, but I can't get a connection with the "DF1" nor "PIC" type (read it could be possible, the latter doesn't really want to play at all). Autoconnect doesn't work with neither cable, neither port (tested DSUB on CPU and also DSUB on AIC+) trying all speeds and and CRC BCC whatever error corrections.
Also tried a straight TP cable directly from PC to the CPU, don't really get how it's supposed to work. Perhaps a crossed cable is needed or both of them connected to a router? No IP-address is written on the CPU where there's room for this.
Even though it says in several other places a USB to COM-port adapter should work, it didn't. But neither did an older laptop with a built-in COM-port.
So I wonder, how should a proper cable for this CPU be connected internally exactly? How do I know if my CPU use RS-232 or setup for DH-485?
There's some kind of ASCII-connection as well it seems... what about that?
I tried running a terminal program to the port as well, I got a stream of repeated data, couldn't really make anything from it. Tried all available speeds up to 19200 bps.
The Windows port settings aren't really crucial are they, they're changed by RSLinx Classic Lite anyway, right? Standard is the speed, 8-N-1 and then Xon/Xoff / Software / Hardware - which doesn't really match all the options in the RSLinx program.
Ideas, suggestions?
Want to make sure I have a proper cable before anything else.
Thanks!
Ideas, suggestions?
Thanks!
