C200HS and NC211
JuanPLC74
Feb 2017
Houston
23
Hello,
I'm getting one of our oldest machines back and running after some sort of software corruption. the backup memory battery died and the uploaded program seemed corrupt.
I pulled the program from an adjacent contemporary machine and downloaded it back to the PLC after clearing the 0x00F1 memory error which erased the whole memory.
On the NC211 I get the alarm light ON. I gives me error codes 1200,1300,5400,1400.. for both X and Y axis. It seems it lost all configuration.
How can i clear this error and reconfigure this card. Im using cx programmer and im not to sure how to program well this older plc whose code is all addresses and no comments or names. I think DM areas all got cleared.
The configuration of the card comes from the DM area based upon the switch settings. Please ensure that you download the DM area as well to the PLC. You will need to cycle power after this happens.
Regards,
Hello, first off I am not a PLC programmer so bare with me.... We have specialized glass lathe that has a C200HS PLC system that has probably sat...
18
2,138
Saludos amigos. Tengo una impresora comexi modelo FS1500, la impresora usa intouch 7 en Windows 2000, viene con un PLC Omron C200HS, también usa...
1,095
Hello, New to this forum and to Omron. Really hoping someone has some input or advice that I haven't already tried. Have exhausted all I could...
1,396
Hi folks Looking to connect an Omron C200HS to Kepserver using the Peripheral port and the CQM1-CIF02 programming lead. I want to try and use...
1,479
Hello everyone, I have a copy of a program with very few named tags and no comments, which is typical. I have been trying to find out which...
2,354
