CL V15 - Sercos Module Issue
curlyandshemp
Jul 2005
Toronto
1,903
For anyone who is using Contrologix V15 with a Sercos motion module be aware of this known issue, snip from Release notes:
/ snip begin
§ MSG Instruction Support for Ring Phase – This release of RSLogix 5000 allows the MSG instruction to be configured for SERCOS Ring Phase control. Two new CIP Generic message Service Types were added for SERCOS Ring Phase Get/Set. Also, an associated Transition To Phase setting was added to the SERCOS Interface tab of SERCOS module properties. (Requires motion module firmware revision 15.06 or greater.)
/ snip end
This does NOT work, I was able to confirm with Rockwell Tech support this AM, that they know is does not work and a fix is NOT in the works at the moment.
Ian Phillips
This sounds more like it has to do with CIP messaging to a module object, rather than something having to do with the SERCOS implementation.
The message instruction returned an "Unsupported Service" code; what exact Service, Class, Instance and Attribute are you using in the Message ? I presume you are certain that the message is pointed toward the correct module (it's an easy mistake because the Path field is on a secondary window tab.)
I am currently am in a PLC class and need urgent help on how the ladder logic would be laid out. I understand how to get the traffic lights to...
19
451
Hi Folks, Looking for support and ideas. We are trying to go online to monitor/fault find on an S7-300 programmed with TIA Portal V15. I can...
358
Hi am new to TIA and i have a challenge when i archive the project it;s being saved as PDF. How to l change from PDF to normal TIA. Your...
611
This is a file from a customer PLC. I believe my partner copied it from their SCADA computer and then went online with it using his laptop. That...
380
Is there any possibility to convert the project in TIA V17 Wincc Professional to TIA V15 Wincc Professional or Wincc Advance?
1,242
