CLX BTR MSG error
eazyu2000
Dec 2006
Orapa
Hi guys please help me with this one. I am doing PLC5 migration to CLX system, im using a 1756-DHRIO to scan remote IO racks with (1747-ASB). Some of Analog IO scans bring up the following error on BTR MSG Block - "Error code: 16#0001 Extended error 16#0076_0113 Error Text: Connection failure". The communication between the remote racks and DHRIO is heailthy and does not have faults. I am using BTR MSG to read analogs and have arranged them in groups to try to eliminate the error but to no vain đź“š
Hi guys please help me with this one. I am doing PLC5 migration to CLX system, im using a 1756-DHRIO to scan remote IO racks with (1747-ASB). Some...
4,429
Controller: 1756-L84E v.35 Prosoft MVI56E-MNETC for ModbusTCP/IP I'm having an issue with some of my write commands. The write command that...
198
I have several Avery scale units and they are configured as Generic Ethernet modules, and I am actually reading the data fine for the weight...
424
What's the best way to move a tag value from the panelview+7 to the clx plc. We display amps from a power meter on the panelview screen, read in...
400
I'm running into an issue migrating a PLC-5 using the newer Logix Designer Export when opening a saved .ACD from RSLogix-5. It has multiple RIO...
622
