CLX dumps program when power lost during trending
Would there be any reason NOT to flash the processor to current firmware?? Weren't some of these kinds of things fixed in recent revs??
I tried the same thing on an L55 I had here. I don't have the 12.23 rev, only 12.24 and newer. Granted I am not running the same project nor am I trending the same tags, but losing power had no effect on the processor memory.
I was only trending one tag, how many were you plotting?
OG
Logix controllers do trending not by sending every value up to the Trend object as fast as they can, but by buffering data inside the controller and sending it up to the trend object.
Running a trend at 2 milliseconds is pretty darn agressive; that's probably faster than the program scan and faster than many I/O modules can react. It also takes up a significant chunk of processor RAM to buffer all that data.
So if a controller was going to have trouble managing it's RAM during powerdown, I would expect that juggling a giant trend buffer would be one of the things that could cause it.
I would recommend upgrading the controller to the newest version of 15.x firmware just because I like many of the editor features that have been added in the past two releases.
Controller: 1756-L84E v.35 Prosoft MVI56E-MNETC for ModbusTCP/IP I'm having an issue with some of my write commands. The write command that...
221
I have several Avery scale units and they are configured as Generic Ethernet modules, and I am actually reading the data fine for the weight...
457
What's the best way to move a tag value from the panelview+7 to the clx plc. We display amps from a power meter on the panelview screen, read in...
415
I'm running into an issue migrating a PLC-5 using the newer Logix Designer Export when opening a saved .ACD from RSLogix-5. It has multiple RIO...
646
We have two sites that are stranded with no line of site, they are handled by phone/modem with a chain that includes: Stranded site (client)...
936
