Clx Ramp Function
plcnovel
Feb 2006
LHR
215
Hi All
I am trying to use a ramp function in clx platform but i couldn't find any ramp function instructions in CLX instruction set. What i am trying to do is if my input is with in a desired range then i want to ramp up an analog output from 0 to 100% (4 to 20 mA) within 20 sec and lets say if it falls out of desired range then i want to ramp it down from 100 to 0 % within 10 seconds.
I was looking for Ramp& sock function (RMPS) & RLIM (Rate limitor functions) but i guess i dont need any of these, unless someone has an idea to use these functions to fulfill my purpose. Any help in this regards will be highly appreciated
Thanks in advance
If you have the FBD option on your CLX, then you can do this simply using the INT (integrator) block. Give it an input of +1 to ramp up and -1 to ramp down. Set the gain to give desired ramp time. Set the input to 0 to stop the ramp (at min/max output).
Another block you could use is the SCRV (s-curve). Set the input to 0 or 100 (step change) and adjust the accel rate as required. Set the jerk rate to a very high value to get a virtually linear ramp.
Hi, Could anyone tell me if they know of a ramp instruction in the ladder logic, for a CLX. I know you can use the AO card to perform this...
4,556
Controller: 1756-L84E v.35 Prosoft MVI56E-MNETC for ModbusTCP/IP I'm having an issue with some of my write commands. The write command that...
201
I have several Avery scale units and they are configured as Generic Ethernet modules, and I am actually reading the data fine for the weight...
432
What's the best way to move a tag value from the panelview+7 to the clx plc. We display amps from a power meter on the panelview screen, read in...
402
I'm running into an issue migrating a PLC-5 using the newer Logix Designer Export when opening a saved .ACD from RSLogix-5. It has multiple RIO...
627
