Communicating AB with Johnson Controls
Russ
Jun 2002
Ohio.. Go Bucks!!!!
261
A co-worker has Johnson controls unit and is trying to find a way to remote notification if an alarm occurs. He is running a lot of AB products on an ethernet hub (also tied into DH+). But, so far, hasn't found a way of connecting the j.c. unit to rs linx.
Any idea's?
thanks,
Russ
May help if you mention what unit so we can know if its even got a serial port etc that may allow it to be connected to net. Otherwise you would need something like another plc to send that alarm bit too then use that plc to communicate to master.
OPC server
RSLinx is an opc server for Rockwell equipment. If by that reference you are asking how to communicate from a HMI to the Johnson Controls unit then try a search using "johnson controls" and "opc server".
From the literature that I've seen it looks like it is a DX-9100. Though I've also seen references for XP(?) or XT-9100 as well.
Thanks,
Russ
Dear All Please help me about Below picture problem.PLC not communicating proper.
182
I need to recommend a PC to replace a customer's old Windows 7 computer. The only thing I need to think through is the serial com port to...
21
698
Hello Friends, We have a powerflex that stopped working sometime last week. It doesn't communicate over the network, or use CCW directly from my...
458
Hi All I'm trying to connect two zebra printers to th PLC through Ethernet. I can ping the Printer through my laptop connected to the private...
363
Have a customer that has a running 1756-l83es, communicating to redundant ABCIP IO servers for Wonderware 2020. This configuration has been...
884
